Am using VirtualDub (Build 16297) with the Panasonic DV Codec to take some captures and convert them into MS MPEG-4 files for archive.
For some reason, the converted files play back just fine in VirtualDub. But in anything else the audio is faster than the video (you hear it and then you see the mouths move).
What is causing this? Are the AVIs I've created just trash? I've used VirtualDub before and not had this problem, but am on a new machine and am trying to figure out what I could have done that created this issue.
Thanks for any help,
Ewan
Just as an FYI I'm running Win XP Pro SP 1 on a 1.3 GhZ PIIIm with 1 Gig of Ram and writing to a Firewire drive, though my internal drive has a 3 Gig Cache and 30 Gigs of free space.
Checked the source file for one of these, and the sound is in sync either way, so it seems to have something to do with the VirtualDub conversion or the playback of the converted file...
Scratching mp4
By nessasaur in forum RestorationReplies: 3Last Post: 3rd Nov 2011, 09:37 -
Fraps is doing my head in/
By oOParaOo in forum Video ConversionReplies: 1Last Post: 30th Jun 2011, 07:19 -
I'm scratching my head - I just want to do simple video conversion?!?!
By Matt_C in forum MacReplies: 6Last Post: 9th Jan 2011, 21:26 -
head cleaning
By kb 801f in forum Newbie / General discussionsReplies: 4Last Post: 28th Nov 2010, 12:09 -
What do you wear on your head?
By johns0 in forum PollsReplies: 15Last Post: 11th Feb 2010, 19:12
