Hi
As far as my ignorance goes, I thought that the THX standard was a specification for building theaters that would conform to the same sound ambience-acoustic as the film mixing rooms, regardless the actual sound system used in the film print (which would be any of the common, Doulby DTSs, whatever) . To my surprise, I´ve seen some home videos DVD-titles that have a label THX-Certified in it. Question is, what exactly is this THX certification for DVD, what´s the actual use for it and what does it, in practice, means ??
thanks
Andre
AFAIK it's just another way for Lucas to make money.
I have the Artisan edition of T2 and it has a THX test for your A/V system.
http://www.thx.com/ -
My understanding - when used on DVDs, etc. - it means that the material - video and audio - has been produced and tested to match the original's quality.
Perhaps I'm wrong. It seems intended as a form of guaranty.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Originally Posted by MOVIEGEEK
is the correct answer more or less ...
they are putting that label on just about anything (if they cough up the money) and it is somewhat decent quality ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
If you want to know about the THX certifications for all media check out www.thx.com
If you wan, here is the link directly to the DVD Specs section:
http://www.thx.com/mod/products/dvd.html -
THX video is nothing new ... this was done first with LaserDiscs then with VHS and now DVD
It simply means that the video and audio were mastered to exacting standards of the THX program.
I don't know EXACTLY what those standards are but basically it's a bunch of technical guidelines as to how to process the video and audio to get the best quality possible from the original source.
THX Optimiser for PC monitor
By smartel in forum Newbie / General discussionsReplies: 11Last Post: 26th Mar 2011, 14:56 -
the abyss THX menu
By tcguy444 in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2010, 10:14 -
how to insert subtitles....thx from spain
By xaviereb in forum ffmpegX general discussionReplies: 1Last Post: 22nd Nov 2008, 10:57 -
How to connect my cable box to my computer~~? THX~~
By bl3311 in forum DVB / IPTVReplies: 2Last Post: 25th Mar 2008, 19:47 -
THX HD DVD Movies????
By ofield1 in forum Newbie / General discussionsReplies: 4Last Post: 20th Feb 2008, 20:45
