has anybody tested which on has better quality in encoding avi to vcd.
Results 1 to 9 of 9
there is a comparison done somewhere on the VCDhelp page. heres it basically
Panasonic
Colour - Average
Sharpness - Average
Blockiness - Good
TMPGEnc
Colour - Good
Sharpness - Good
Blockiness - Average -
panasonic (PWI) all the way!!! i do agree with yeshi on the color aspect tho, PWI bleeds a lot. if you hate blocks, go panasonic. never seen anything that compares.
later bater. deltaboy -
Pansonic
+never errors out on bad DivX files
-very inflexible (just try to resize!)
TMPGEnc
+very flexible
-errors out on bad audio or video -
Overall, video quality for Panasonic vs. TMPGEnc for VCD standard MPEG-1 is about the same. Panasonic does some things better, TMPGEnc does other things better. My eyes prefer Panasonic encoded MPEG over TMPGEnc overall, so that's what I use for standard VCDs. The quality difference between Panasonic and TMPGEnc is mostly subjective so it will depend on you.
TMPGEnc probably has better performance.
Regards.
Michael Tam
w: Morsels of Evidence -
I would like to know why all of you are still discussing about panasonic. As far as I know, Panasonic is a dead product. No update since more than one year.
What release you are discussing? stand alone or adobe plugin?
Can it work with Adobe 6.0?
I've tried it 6 mths ago, and the result is very bad, TMPG is perfect. And if you burned it with Nero, I heard that Panasonic will not suitable. -
It should be obvious why people are still using Panasonic -- because to some eyes, it is the highest quality MPEG-1 encoder at VCD bitrates available (i.e., better than TMPGEnc).
The plug-in and stand-alone versions offer the same quality.
The plug-in version works with Adobe Premiere 5.x and up ("plug-in" as in Adobe Premiere plug-in).
The newest release is 2.51.
If your results were bad, you stuffed something up.
Panasonic encoded streams work fine with Nero.
Regards.
Michael Tam
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
Need Help Panasonic HDC-HS250P (AVCHD), USB to Windows Media Encoder
By planet_bill in forum Video Streaming DownloadingReplies: 1Last Post: 13th Aug 2009, 15:40 -
ConvertXtoDVD Encoder Quality
By SCDVD in forum Video ConversionReplies: 17Last Post: 2nd Jun 2009, 14:23 -
Encoder with no quality loss
By JamesDV in forum MacReplies: 25Last Post: 8th Apr 2009, 12:01 -
Better encoder than TMPGEnc
By dazza555 in forum Video ConversionReplies: 7Last Post: 15th Sep 2007, 10:45
