Hi, i have a NEC 1100A DVD Burner and i'm bored to make backup of my dvd on 2 rare DVD+R media working on my DVD burner (using ritek media found on ebay.ca) i would like to update my DVD burner and backup my DVD on only one dvd ( 9.4 gb media? ) and i would like to know if anyone tested any burner with these media and if i can burn these media on NEC 1300 else witch burner i must use..
Thx a lot
Results 1 to 10 of 10
Take the lead as you can ;)
what's that?
http://www.shop4tech.com/item1606.htmlTake the lead as you can ;) -
oh i see.. while burnig i must turn the dvd..??
whitch media is use to burn commercial DVD??Take the lead as you can ;) -
Golden,
That's double sided.Each side approx 4.7 GB
You have to flip when recording. -
arf... i must lost quality or content.. okay.. thanks..
Yes, you must turn 9.4GB DVD-Rs. They work great if you have a Sony DVD that can flip discs automatically!
Commercial DVDs are pressed and bonded. There is a great UK site that describes the process for all DVDs (including DVD-18s like Gods and Generals):
http://www.disctronics.co.uk/technology/index.htm -
Commercial DVD's are pressed not burned.Originally Posted by Golden"Terminated!" :firing:
DVD-9 DVD-R's are unlikely to be with us in the forseeable future - creating a media and a mechanism where you can burn one layer through another without destroying that first one in the process at such a narrow difference of focal length is not an easy task.
Plus the resulting burn has to be reliable and compatible (the reflectivity of two organic dyes is not going to be even close to the silicon alloy usually used in pressed discs), and bit management is an issue too - the second layer by design has to have less data on it than the first, and the complexity of an authoring program on its own that can take this into account and create a complaint disc means £££ / $$$.
Don't forget the glue holding the two layers together can't be affected by the burn process either - the science between the glues used in DVD's is a nightmare and covered by several patents as it is...
9gb .ts > 4gb .mkv
By NotSoEasy in forum Video ConversionReplies: 28Last Post: 5th Mar 2012, 21:21 -
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
How to make AVI file to 1.4GB ?
By zovx in forum Video ConversionReplies: 2Last Post: 5th Feb 2010, 11:24 -
convert DV to 4GB file
By bensonlo in forum Video ConversionReplies: 3Last Post: 5th Mar 2008, 16:15 -
About 4GB Memory
By mn072065 in forum ComputerReplies: 8Last Post: 30th May 2007, 05:31
