Which allows you to add music on the background and animated stuff and yet not having to spend 100s of hours maybe 2-3 hours ?? ^_^ Suggestions
Results 1 to 11 of 11
do you want something where you supply the raw materials, and the authoring software does the work for you?
or are you looking for authoring software that supports those features, and you will do the grunt work of precompositing motion menus, editing the audio loops, etc.?
I find DVD Lab very easy, but I also don't expect my authoring software to do anything except authoring, so I do all my compositing, sound editing, image prep for menus, etc, in different applications.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Check out Ulead's DVD WORKSHOP:Originally Posted by andylouie
http://www.ulead.com/dws/runme.htm
Jerry Jones
http://www.jonesgroup.net -
Specialist.. he wants easy.. Workshop is definitely not easy!!! Unless you want to give a step by step guide
Specialist is a spammer, trying to sell Ulead. He's already been warned by atleast one mod on here recently, but he obviously hasn't been deterred. I've seen him recommending DVDWS to someone only asking for a burning programme
He doesn't have peoples best interest at heart, he's only interested in a potential sale/s.
Ulead DVD workshop is very easy, almost as easy as Ulead movie factory, only with more options.
There are guides on this site that explain parts of the process, but am surprised that a start to finish guide has not been done. Hmm....... Maybe I'll do one
DVD Lab is really the best choice. I pesonally use Maestro, which has a steep learning curve but is actually pretty easy to use once you read the manual and the doom9.org guides. I've never used scenarist but the doom9.org guides make it look pretty involved (I'm sure that once you get into it it's not that bad, sort of like the adobe products).
The truth is that if you want to have full control of the authoring process there are a lot of potential steps/options. The one click programs make life easier but they don't give you as many options. More options means more freedom, and more freedom means more stuff you can screwup
Dollar for dollar DVD Lab is the best choice. After that I'd say Encore (nb - i've actually never used encore and it looks like it only accepts full D1 clips, but other wise all reviews are glowing). -
Ulead Movie factory 2 is easy and cheap. Specialist is correct about Ulead workshop having the capabilites, however Movie factory2 is easier except it can't do the animation. I use MF2 all the time even when I have more capable softwares like; Vegas, workshop, and mediastudio. The only thing that pisses me off about MF2 is that you can't fade the audio in/out on the slideshows.
Everything but the animated menu: DVDit! PE
Easiest anymation
By jimmyy in forum EditingReplies: 10Last Post: 19th Jul 2012, 16:20 -
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
Easiest Cutting Program?
By Merkaba188 in forum EditingReplies: 9Last Post: 4th Nov 2009, 22:25 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04
