I have followed the guide to convert MPEG2 to AVI using VirtualDub MPEG2. The audio is always out of sync. How can I fix this? I am using the Divx 4.12 codec and LameMP3 codec.
I tried the other guide, by using Goldware to extract the audio, then using VirtualDub to do a direct copy of the audio. It still desyncs are places. I compared the 2, and they happen at the exact same places.
You want to go ahead and resynch. Click here. Why are you converting from MPEG to AVI, if I may ask?
Hello. -
You could try another mpeg2/dvd/svcd to avi tool like vidomi or
https://www.videohelp.com/tools?toolsearch=§ionselect=9&orderby=Name&convert=DVD+to+...+or+List+tools -
Originally Posted by Tommyknocker
What a guy. Can you capture in AVI and save a conversion step. Some of the available AVi codecs are very efficient and give comparable images to MPEG.
Hello. -
I am not sure if I can capture in AVI. I have a Hauppauge tv tuner. I am using PowerVCR to record.
MPEG2 to AVI or whatever VirtualDub will use
By bpatters69 in forum Video ConversionReplies: 4Last Post: 1st Nov 2009, 19:19 -
mpeg2 (4:3) to avi (16:9)
By kouras in forum Video ConversionReplies: 3Last Post: 3rd Feb 2009, 09:53 -
dv-avi(mpeg2) to avi compression
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Feb 2008, 08:44 -
AVI to MPEG2 conversion
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 6th Aug 2007, 18:42 -
avi to mpeg2
By n2lakers in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2007, 14:56
