Results 1 to 9 of 9
  1. Does it matter if I choose the option: "Non- Interlace" or "Interlace" under "Encode Mode"
    And what does: MAC, SEAM, COMPONENT & UNSPECIFIED mean under "Video Format"?
  2. Bit more info. It would help to know what you are encoding from, what your output file is going to be and what software you are using.
    May 2003
    Pal Realm
    Originally Posted by yysie
    Does it matter if I choose the option: "Non- Interlace" or "Interlace" under "Encode Mode""
    You should keep the choice the same as your source. Especially, keep interlaced if you will be watching on TV and not PC only.
    I've never seen (or noticed) those. What program are you using/seeing that in?
    More info might help others give you good answers.
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
  4. Oh, I'm sorry... I'm using TMPGENC... I'm Converting to DVD (352x576)...
  5. I also want to know which resize filter is the best cause when I convert 720x352 with TMPGEnc the resulted file is not very well...
  6. If your original source is 352x576, then resizing to a larger resolution will always look bad. Resizing down is a whole nother story, that should be OK.
  7. Yes I know but it looks like the outputted video got some vertical lines... I choose a very high bitrate so I think it's the resize fiter.... Converting to standard SVCD is much better!
  8. If you are encoding using a TMPGEnc template there is no need to use a resize filter. The compliant sizes are set in the template. 720x352 is not a compliant DVD resolution.
  9. O I'm sorry but it a bug in the site! I mean 720x576 2 352x576...
