Just recently, after I downloaded the new version of DivX. I tried to play a video on WMP and the image was flashing(of blinking) really fast, then I realised quite a few of my videos are doing this when I try to play them on WMP now, everything else was fine except the it refuses to stop flashing
Anyone had the same/similar problem?
Any ideas on how to solves this problem?
Thanks in Advance
//Ib
I've never had that exact problem. But I have read here that codec packs can cause problems.
Have you installed any packs? If so, search for threads for advice on removing them and only install individual codecs as you need them.
Hope that helps.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Originally Posted by Gees
I did install a Nimo codec pack on my computer, but that was after the flashing started, I thought the codec pack would help... it didn't
Before that everything worked fine, that is until I downloaded the new DivX, could it be something that came with DivX(not likely eh....)?
Thanks for the help so far though
//Ib
How to make Media Player Classic's window size stay the same when playing m
By DigitalAbstracts in forum Newbie / General discussionsReplies: 5Last Post: 28th Jun 2016, 19:35 -
Need help for Window/VLC Media Player
By Neil_2004 in forum Video Streaming DownloadingReplies: 2Last Post: 27th Feb 2012, 19:05 -
How to send video of window media player thru mail
By rajshri in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2009, 12:46 -
window media player does not work
By romanstopme in forum ComputerReplies: 8Last Post: 6th Dec 2008, 12:21 -
Window Media Player and TV
By BobV in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2008, 16:34
