Hi,
I have checked the whole forum for my problem and have checked my xvid for bad frames, ect ect...no bad frames reported.
Tmpgenc just will not convert this xvid to dvd, i dont know wot else to do. If gets to around 20 minutes before the end of the movie, and just freezes.
I have also checked on enviromental settings on tmpgenc, tried wot the forum suggested, no joy there either.
Please can someone help me here.
thx
Results 1 to 9 of 9
Which version?, there was a version (I think 2.511??) that would freeze all the time. Try a newer version (earlier version will also help) as there was only one version in past few months that constantly froze.
Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge. -
Been ther myself
Did you scan 4 bad frames with vdub-mp3-freze not std (vdub) ?
Is the audio in wav format ?
and you say you altered the enviromental settings (like this ? https://www.videohelp.com/forum/userguides/119019.php)
Well if you did all the above all I can suggest is to uninstall/reinstall Tmpgenc (delete everything in the Tmpgenc folder if any thing is left behind) -
BTW I'm using v 2.511.51.160 working fine
You could try to encode just the bit where it freezes to see what happens. -
Hi all,
I have had problems encoding YUV .avi files with TMPGEnc; I usually frameserve with AVISynth. Including a call to ConvertToRGB24 once I'm done stitching things together with AVISynth script has greatly improved the stability of my encodes. It has something to do with Windoze VFAPI's conversion of YUV to RGB, which is what TMPGEnc expects its input to be in. Using AVISynth instead of VFAPI to do the conversion solves this problem. BTW, I am using TMPGEnc 2.57.
CogoSWSDS -
I changed to an older version and it converted perfectly on 1st try.
Thanks for all the replies peeps.
TheDJ® 8) -
Try the next version when it comes out (but keep a copy of your working version just in case you need to revert back)Originally Posted by TheDJ®Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge.
Picture freezing
By Toes01 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Jan 2012, 14:52 -
DVD freezing?
By XyBeRz in forum Authoring (DVD)Replies: 10Last Post: 28th Dec 2008, 23:26 -
Tmpgenc keeps freezing
By WinSpecToR in forum Video ConversionReplies: 6Last Post: 12th May 2008, 00:08 -
Freezing DVD-R
By markannab in forum Authoring (DVD)Replies: 7Last Post: 3rd Feb 2008, 03:01 -
TMPGENC DVDAuthor 3 freezing up during output process
By CodySave in forum Authoring (DVD)Replies: 1Last Post: 21st Jul 2007, 11:57
