When i open a VIDEO_TS in ifo edit i always go to the bottem off the page to delete the warnings out of my back ups....
But when i double click on them this messeage pop ups.....
MPEG2DEC: Error during Decoder Initialisation
some times this pops up as well when im using TMPGenc Author
Can any one tell me what i need to do to fix this problem
Ive Been on the phone to pc world they tried to help but failed they gave me a number for this kind of crap & they didn't have a clue....
Does any one know of any pc sites where i can go to and explain my problem????
Any help would be Great -
I think MPEG2DEC has problems decoding video if its below a certain number of frames. Most of the times I get the same error when trying to view shorter things like warnings in IFOedit. When this happens I just load that vob in dvd2avi and scroll through it to see what each vob-id is, then I go back to Ifoedit to remove those vob-ids. While in Dvd2avi, as you scroll it lists the vob-id you are in at the top.
Can IFO-Edit merge files?
By Djard in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2011, 10:50 -
trying to edit dvd get VTS_18_0.IFO contains bogus data error, FIX?
By Denvers Dawgs in forum Authoring (DVD)Replies: 6Last Post: 2nd Apr 2011, 16:45 -
Extreme frustration: PAL to NTSC, using IFO Edit
By gabelogan99 in forum Authoring (DVD)Replies: 4Last Post: 22nd Jan 2011, 14:02 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 10:39 -
using ifo edit
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 06:19
