    Mar 2002
    Croatia
    Hello,
    I am using TMPGEnc 2.520.54.163. and if I try to convert DV to MPEG-2 from my camcorder, it works.
    If I edit DV in Premiere 6.5 and export it also in DV format, when I try to load exported DV in TMPGEnc, an error "invalid or unsupported format" occurs.
    Where is the problem?
    Thanks...
    Mar 2002
    Hawaii
    You might be lacking a codec. Try installing one of the DV codecs in the "tools" section to the left.
  3. Member dlawedor's Avatar
    May 2003
    Grosskrotzenburg, Germany
    Sometimes it helps not to try once only ... By trying the same file a second time it works ... sometimes !!! dlawedor
    Mar 2002
    Croatia
    Yes, you are right. DV codec was missing. But how you explain that I manage to load DV video captured from camcorder into TMPGEnc?
  5. Member daamon's Avatar
    Melbourne, Oz
    Stile,
    What codec did you use? I doing some similar work and may run into the same problem.
    Thanks....
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  6. Member DVO's Avatar
    Apr 2002
    Hi,
    TMPEnc can open DV-2 files but not DV-1 files. At least on my computer. Premiere render DV-1 files so they cant'b opened in TMPEnc for convertion. Check the tool section for a DV-1 <-> DV-2 convertion tool.
    Almost forgot, when Premiere capture DV it's in DV-2 format.
    Mar 2002
    Croatia
    Daamon...
    I am using Mainconcept DV codec 2.4.4.
  8. Member daamon's Avatar
    Melbourne, Oz
    Nice one Stile, cheers. Much appreciated.
    Carpe diem.
