    Sep 2003
    CloneDVD has 3 burning modes, and I'd like to use the one that is best for backing up my dvd's. Also, I should say that i use, DVD Decrypter, Ifo Edit, DVDShrink, and then CloneDVD.
    Ok, the modes are:
    1. Copy DVD Titles - copy one or more DVD titles.
    2. Clone DVD - clone a dvd including all titles and menus.
    3. Write Existing Data - process or write DVD files ISO/UDF images.
    I've so far used #'s 1 and 3 to burn back ups (all dvd's worked, cept for skipping in my ps2), which of the 3 is best?
    Thanks 8)
  2. I use option 2 and de-select anything I don't want on the final disc.
    Jul 2003
    The Scottish Highlands
    Assuming that you have used decrypter and ifo and shrink, then I assume that the disk is all ready down to size and ready to burn, in which case use option 3.
    Sep 2003
    Toronto, Ontario, Canada
    I must be doing something wrong because I use DVDShrink to rip (extracting only the main title and the 6 channel soundtrack) and then immediately run CloneDVD, choosing the first option. After 15 minutes it's done.
    On the few occassions that the backup is too large to fit on a DVD, DVDShrink warns me of it being too large but I choose to back it up to the hard drive anyway. CloneDVD then automatically shrinks the information down even further to fit exactly on the disc before burning.
