I notice that included in version 1.5 is the ability to create DVD Menus. There is also a 'Background' folder which is supposed to contain 'over 100' templates.
The version 1.5 installed on my system does not have these background templates and I regularly update my program using the 'auto update' feature.
Is there anything wrong or do I have to download the templates manually?![]()
Any comments would be appreciated.![]()
Results 1 to 9 of 9
007Guest
Hey,
where did you read about the templates? As far as i know you need to create you own background images. With a program like dvd menu studio or a image editor.Greatings,
Yf -
Ths initial install from the SVCD2DVD.msi file creates a Background folder with 88 images in it. However these are images not templates.
007Guest
Thanks for the response, guys.
I apologise for any confusion in terminology - I am referring to background 'images' rather than 'templates'.
But the fact remains that I still don't have any of the 88 'images' in my Background folder and the software is working well on my system. Chrissyboy, do I have to uninstall/reinstall everything OR can I download the images separately? -
its part of the initial install. How big is your msi file?
well if thats what you installed from then you should have the Backgrounds folder. My only advice would be to uninstall & reinstall.
Can you screenshot your SVCD2DVD folder? (as in https://www.videohelp.com/forum/viewtopic.php?p=654730#654730)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
007Guest
Hi ChrissyBoy
Many thanks for your response. I have uninstalled/reinstalled and everything is okay - the background images are great!
Thanks for a great program and keep up the good work!
PS - I sometimes encounter video/audio synch issues with certain mpeg files after conversion with SVCD2DVD. I have checked the FAQ section on your website which has an entry on this topic but no comments.
Maybe it is because of bad/non-compliant mpegs, but if you could point me in the right direction on this matter, it would be greatly appreciated.
Thank you once again
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 17:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 20:09 -
How to grab images from VIDEO_TS folder ?
By ralf07 in forum Newbie / General discussionsReplies: 6Last Post: 3rd Nov 2011, 10:33 -
I don't get any movie.DVD folder (audio_TS & video_TS), help!!!
By dbedolla in forum MacReplies: 1Last Post: 10th Nov 2009, 04:21 -
svcd2dvd wont clear dvd_output folder
By geb in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 14th Dec 2008, 16:00
