I just spent the whole day testing my brand new Panasonic DMR-E50, and there seems to be a major lipsync problem. I discovered this instantly when I turned the unit on. It's noticeable both when I'm watching live using the tuner, and on the recordings I have made on DVD-RAM.
I have connected a digital satellite receiver to it, and use RGB via the scart connection AV2. The TV is connected to the AV1 scart and use RGB signals. The digital audio output is connected to my surround receiver.
I also have the sat. receiver connected to a VCR, for verifying my results.
The VCR recordings are fine, while the Panny recordings are clearly out of sync.
Does anybody else have this problem?
I know that the HS2 model has been reported to have these lipsync problems too, so it might be a Panasonic problem. I also wonder if there's a firmware fix to this issue.
Anyway, I'm very disappointed, and I think I will return the unit to my dealer. It's useless in this condition.
(My TV is a 32" Panasonic 50 Hz widescreen, and I live in Norway.)
Results 1 to 1 of 1
Panasonic DVD Recorder-VCR Combo unit model "DMR-ES35V"
By Syd Jamal in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Jan 2010, 15:27 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 13:09 -
Panasonic DMR EZ25 Problem
By Undead Sega in forum DVD & Blu-ray RecordersReplies: 6Last Post: 8th Jan 2008, 10:17 -
looking to replace a panasonic DMR -E50 any ideas?
By edmond in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Oct 2007, 12:34 -
Panasonic DMR-EX85: Recording NTSC discs on UK model
By webstar in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Jul 2007, 17:57
