hi hope someone can help me?? i have d/l an avi film which i want to burn as a dvd i am trying to convert the file to mpeg using TMPGEnc but when i do that the file becomes 118% the size of the disc the bitrate is 2000 and i can only go up which then makes the file even bigger please help me before my writer goes out the window lol![]()
cheers
kev
Results 1 to 16 of 16
No that's no warez because there are a ton of legal avi (and DivX/xvid) files you can d/load. Movie trailers, home videos, fan parodies (not sure if all fan parodies are legal thou), etc. etc.
File size a combination of bitrate and source runtime. The size of the source file, the quality of the source file, the resolution of the source file, the resolution of the encoded MPEG, etc. has no affect on file size.
If the bitrate used is 1150kbit/s then a 10 sec clip = 11500 kbits. Always everytime. For any given runtime there's a bitrate that will result in filling you media (CDR or DVDR). You can use a bitate calculator to find this, look to the left under Tools.
I personally like the DVDRHELP.COM bitrate calculator, simple but gets the job done. -
Something aint right. 2,000KB Bitrate 2 hour clips shouldnt be >5GB. I can fit 50 minute clips on a CD-R at higher bitrates.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Hi m8 try taking the sound off with VirtualDub then go to tmpeg and put it back together select the film then select the audio you have taken off..
Yes, VBR audio screws up TMPGEnc calculations for output filesize. Save the audio as uncompressed wav and use that as the audio source in TMPGEnc.
ok i give up!!!! i have found out how to split the film in half but i cant find out how to split the film from sound???any help??
thanx kev
In virtual Dub, load the video and choose
"file > save WAV"
from the toolbaer"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Make sure you select full processing mode and no compression. You should end up with a file approx 10 MB/min
hi guys need help again!!! i have managed to save the sound as a wav then burned all to dvd disc but now i got a sync prob!!!! it starts of fine then starts togo out!!! what can i do???
I can't.. tell you shoot yourself because that's not allowed,
so instead I wil recommend that you read all the guides
Help with large TS file
By mejallen in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2010, 20:44 -
Help to compress large HD File
By camlachie in forum Video ConversionReplies: 10Last Post: 10th May 2009, 13:47 -
large iso file
By fabpozzi in forum Authoring (DVD)Replies: 10Last Post: 13th Dec 2008, 13:10 -
Avi file too large for CD
By hitmanhill in forum Newbie / General discussionsReplies: 17Last Post: 22nd Jan 2008, 15:19 -
Large .dvr-ms file?
By ukcat in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2007, 16:47
