yeah I noticed that but it's only 5 votes and RNM has a smaller rating of 8.02 (3 votes or something) last time when I looked earlier today though I wonder what will happen now you have brought it to everyone's attentionOriginally Posted by tgpo
I was gonna suggest people go post their comments in there but I doubt it would be a honest vote now though![]()
Results 61 to 90 of 90
Originally Posted by tompika
it's nice to finally have a laugh in this thread -
Originally Posted by MackemX
If you take a step back, that comment in the other thread about you and nero was funny, because you had to be reading this thread to get it.
And if anything, thayne's my little friendEjoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Interesting read so far...
My experience with Nero (5.5.8.something, latest download):
When I burn Sentinel DVD-R: no problems whatsoever.
When I burn (cheapo) DVD-R (Supermedia 1-2 speed): sometimes I get the "could not close disk" error, but when I check it it will play correctly (yes, I did check towards the very end) both on my DVD-ROM and on my standalone (CyberHome CH-402). The errors occur irrespective of whether I burn at 1 speed or 2 speed.
So, based on this, I would say it's not Nero but it's the media that makes the difference.
Btw, when I run into a problem and before I say that sofware xyz sucks, I have the following approach:
Step 1: Try and blame mself (i.e. find out if I - God forbid! - may have made a mistake...)
Step 2: Check whether I have the latest version.
Step 3: Look at other people's experiences and see whether they match mine.
Step 4: If then I'm still experiencing the same problems, I just blame Windows 8)
Frank -
Originally Posted by Ejoc
and thanks for the compliment -
Thayne, perhaps we should ask the moderators to give you your own forum so I don't have to see your beligerant posts, then..."Terminated!" :firing:
Originally Posted by yysie
(UDF1.02 of course)You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Here are the facts.
1. More people use Nero than any other burning program. - There is a reason for this.
2. RNM is a good burning app, but the user interface is non-intuitive. It's quite easy once you know the settings though.
3. Only a minority of Nero users have burning and playback problems with the app. This certainly does NOT mean that nero sucks.
4. MANY RNM users have reported making coasters with the app. - Question: Does this mean that RNM sucks? -
ive been using nero for 3 years and it can be anywhere from great to really crappy depending on which version they put out to fix a problem and introduce another one,the newest version wont let me burn 79:57 min even with overburn checked so i just image the files and burn with alcohol.
Originally Posted by cplevel42
2) No comment
3) Says who? I'm not talking about having problems, I'm talking about burning to DVD-Video standards
4) Nope it doesn't"Terminated!" :firing: -
I think people have trouble with Nero, they just don't know it ! because the disks works in their own players. Here's an example:
I Burned an Optodisck001 with Nero, the disk plays on my 454 but jumping chapters goes slow, then i burned the same files on an Optodisck001 with Clonedvd and it jump chapters much faster. Then i scan the disk's with Kprobe and as expected the Nero burned disc messed up at the end. -
Originally Posted by Soptobbe
I ran a test on an original DVD to see just how different my results would be and as it shows there isn't much difference and it's pretty obvious my Lite-On is having issues but regardless the Nero test ain't that bad considering the orginal test results
so even my original DVD ain't that impressive but I that's probably down to my pretty worn Lite-On DVDROM drive
I'm pretty sure if I burned an Optodisck001 with Nero I wouldn't get the same results as you say, but if you get bad results which I believe you experience, for some reason I don't -
Originally Posted by steptoe
I removed entries from the registry regarding the upper and lower filters and also uninstalled all the software concerned and then reinstall again in a particular order and everything was fine again
why not try another software like RNM which may work just fine on your current system -
I removed entries from the registry regarding the upper and lower filters and also uninstalled all the software concerned and then reinstall again in a particular order and everything was fine again"Terminated!" :firing:
Originally Posted by thayne
just in case you missed the thread it's HERE with the same issue mentioned HERE
I do also know that some people would rather move on and not bother finding out what the issue is. I could quite easily have taken the same attitude that both programs were crap because they conflicted. If I was going to blame anything then it would be IC8 but did I cry about it?. Did I say IC8 'sucks'. Nope, I just got on with it and resolved it instead and actually think IC8 is quite a good application to have
You will also notice some users didn't have issues when they installed IC8 as well as having Nero on their system but did I go on the same way as some are at the minute because it didn't work for me?
I realise you have a serious issue with nero but to keep on repeating everytime you think a whining spot is available is proving to be very repetitive and a little bit boring -
I'm not saying Nero sucks because of conflicts or that it just doesn't work. I say it sucks because it doesn't make Compliant DVD-Video disks. I never had a problem with it "not working" and I still use it for burning CD's. My whole point is it doesn't make DVD-Video compliant disks.
it does seem strange that Nero checks for DVD-Compliance and complains if something is wrong so what DVD-Compliance is it working too?
have you seen FAQ on Nero's site HERE
one helluva disclaimer if you ask me -
i have ben using nero 6.0 for about 2 months now i have some problems. It workes great on 90% of DVD players.But as far as ease to make a avi,mpeg.divx or what ever the nerovision express2 is great. But most of the time when i talk to other people they dont have the nero express2 set up correctly.
I do it this way
open nero start smart .. then DVD pulldown at the top right ..click photo and video ..make a DVD-Video
now im in nero vision express2 add the avi file ..and do what ever i want to it .. edit it front or the end change the sound to fit more in the more options at the bottem it will automaticly reduce the file for you. .. then burn to image or DVD drive or in file mode... and i need all the help i can get
I have found out that the cheep DVDs will not play on some DVD players using nero then i burned the same way using nero with better DVDs and they work fine -
Thayne, where are you coming from with this absurd remark?
RMN and Nero use the same specs for burning DVD-Video.
Since switching to version 5.5.10.20 (which fixed UDF errors), I have yet to find a player that rejects discs (including old picky ones I know about). :P
Actually, RMN, Roxio 5 and InstantCD/DVD are the only three burning apps to ever crash on my system on a consistent basis. But you don't see me ranting "RMN sucks".... I just say "Nero works!"... In fact, the only reason I canceled making a RMN guide at www.lordsmurf.com was because RMN was crashing while trying to get screenshots. That, bundled with the fact I rarely use it, got it canned.
And even then, it's just my system rejecting RMN. It obvisouly works on sombody's system. You like it. And I say good for you. You found what works. That's the important part.Want my help? Ask here! (not via PM!)
for the record, the backed up copies DID play on MY player with no freezing, so I assumed that they would automatically work on his too. Such was definitely NOT the case. I basically use Nero to burn SVCD's and music discs. But I'll NEVER use Nero to burn another DVD again! -
is this still doing the rounds
just use whatever works best for you and don't worry about what others use. If people did the world would be a happier place
I must unsubscribe -
NERO users are nothing more than testers. Why would AHEAD waste their blank CD/DVD for testing when there are so many guppies willing to waste their money and do it for them.
jm2c(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
I've burned over 300 (admittedly, not huge, but enough) DVDs of various formats with Nero, including a batch of 50 2x -R that were going out to people with unknown set-top players. Haven't had a single problem with Nero - the only problem I had whilst burning was with a bad batch of Verbatim disks (CMC).
My only comparison is Roxio Easy CD 5 Platinum - lots of blue screens and a reformat after it made Windows not see my optical drives.
I'm not saying the sun shines out of Nero's ass, but there are enough happy customers to conclude that it doesn not 'suck'.Regards,
Rob
Want to use K-Lite? - DON'T DO IT!
By jeanpave in forum Software PlayingReplies: 45Last Post: 15th Nov 2010, 22:04 -
I don't get it?
By penny1stu1 in forum Newbie / General discussionsReplies: 1Last Post: 5th Apr 2010, 05:34 -
Need Help But don't know how to ask the question
By NickHedge in forum Newbie / General discussionsReplies: 5Last Post: 8th Mar 2010, 04:23 -
don't like what's on tv?
By deadrats in forum Off topicReplies: 2Last Post: 16th Feb 2010, 09:42 -
Subs don't show properly I don't know what to do
By atai in forum SubtitleReplies: 1Last Post: 8th Oct 2009, 07:44
