Using TMPGEnc to create a M2V file from Xvid for DVD, the files finish up smaller than calculated.
I have produced many M2V files with no problems until now.
I recently re-installed windows and everything else and now I have this problem.
Any ideas?
Can you tell us what is the length of the video in seconds, the bitrate settings you used to encode and the overall .m2v file size?
The more I learn, the more I come to realize how little it is I know. -
Film length 5687sec
Bitrate 6246kps VBR
Overall M2V 2,965,929kb
Thanks -
OK, you are correct, the file size it too small.
6246kps / 8 X 5687 gives 4.440.125 kb, (i.e. 4.33Gb).
Try playing the .m2v file with Windows Media Player. Check the overall length in minuteseconds. The file probably is cut short (perhaps the encoder aborted).
If the movie is complete, then obviously the bitrate is smaller than the one you think you have selected.
Encode it once more and see.
BTW, if the .m2v file is 4.33Gb long, you will have trouble fitting it with audio onto a DVD-R.The more I learn, the more I come to realize how little it is I know. -
According to WMP the file is 50min 37sec which would explain the file size.
But a quick scan through shows the beginning and end credits!!
I have tried the conversion twice, with the same result.
It should fit on a DVDR with 192kps audio?
May be I should try another Xvid to see if its that, that is causing the problem. -
Did you encode with CBR or 2pass VBR? It's not possible to predict the final size of a CQ_VBR encode.
Did you lower the framerate?
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
Getting larger files than expected using Xvid to compress AVI
By pronco in forum Capturing and VCRReplies: 50Last Post: 7th Sep 2011, 10:42 -
Error: File shorter than expected
By justin79 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 15th Jun 2011, 22:55 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 20:48 -
Report: FCC expected to rule against Comcast
By TaoTeWingChun in forum Latest Video NewsReplies: 1Last Post: 28th Jul 2008, 09:52 -
Is there any expected release date for a vista service pack?
By yoda313 in forum ComputerReplies: 10Last Post: 19th Jul 2007, 09:02
