I have the latest version of nero 5.5 (I believe it's 5.5.10.50) and I'm having problems with nero locking up whenever I select the type of media to be DVD. As soon as I choose DVD, my mouse freezes and I have to reboot the computer. I'm running Windows 98SE and using a Ricoh MP5125A DVD+R/RW and it came with nero 5.5.
If I use the nero wizard to set up a DVD for recording, everything works fine until I get to the burn step. At this point it also locks up in a similar manner.
The last thing I tried was to update the DVD's firmware. This did not seem to have any effect. I downloaded the latest nero ASPI drivers but haven't loaded them yet (that's next).
I also have Roxio Easy CD creator 5 loaded on my system and I think I'll also try to remove it as I've heard that there can be conflicts between it and nero. Should I uninstall both nero and roxio and then reinstall nero?
Any other ideas anyone could offer would be greatly appreciated. I haven't been able to burn a single DVD on my system yet due to such lockups.
TIA
Here's a bit of an update. Nero doesn't exactly totally lock up allthough it did seem like it was doing that at first. It turns out that when I select something in nero that has to do with the DVD drive, my cursor/keyboard freezes as if the system is locked up. However, if I wait 20-40 seconds, everything comes back and I am able to continue as normal. So, it seems as though there is some sort of DVD drive detection that is taking place and it takes a lot more time than it should.
As things are (now that I know it wasnt totally locking up), I can get by. It's just annoying having these extended pauses.
Select subtitles automatically in a DVD
By dexter30 in forum Newbie / General discussionsReplies: 0Last Post: 7th Nov 2010, 10:38 -
Looking for software to select 10 min clip from DVD
By jimdagys in forum EditingReplies: 3Last Post: 17th Apr 2009, 09:20 -
DVD Fab will not let you select video resolution?
By David97 in forum Video ConversionReplies: 2Last Post: 20th Apr 2008, 19:56 -
How to take Two DVD's and Merge to One with Menus to Select
By videocheez in forum Authoring (DVD)Replies: 0Last Post: 31st Dec 2007, 18:50 -
DVD Player Locks up Playing DL dvd+Rs, What to do?
By slipknotmr in forum MediaReplies: 1Last Post: 23rd Nov 2007, 23:59
