Hey guys, how do you add a background music to your menu with TMPGEnc DVD Author?
Same problem here. I Create an mpeg file with sound and let TMPGDVD used it as background. Still no sound !! You could try this method and see whether you get sound. Remeber the small clip must be dvd-compliant. Or else junk the program!!Let me know. Good luck
I found out a way...you use the background picture (jpg, bmp) and put it in the video part of TMPGEnc (not the DVD Author)...and add the audio in the audio part...(wav)...den you just start coverting. but some reason whenever you put motion on for TMPGEnc DVD Author, it lets you have motion depending how long you decide to want the motion to run; but when inserting a background music and enabling motion...it won't play the whole song...the song will start over with the motion enabled....Do yall know how to make the audio play the whole song while letting the motion just repeat its icons instead of the whole menu?
TMPGENc Authoring Works 4: Menu crashes after I add background music
By silentmachine in forum Authoring (DVD)Replies: 2Last Post: 11th Aug 2011, 16:32 -
add background music using ffMpeg or any commandline tool (free)
By Shohag_ifas in forum AudioReplies: 2Last Post: 21st Jan 2011, 07:25 -
How to add background music?
By coody in forum AudioReplies: 2Last Post: 25th Sep 2008, 17:04 -
help! adding background music
By Keier in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2008, 15:30 -
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 13:56
