I need to convert .vob files into .mov files so I can edit them in Final Cut Pro. Is there a program that converts directly from .vob to .mov or do I need to convert to .m2v first and then to .mov? I tried to convert the .vob to .mov using mpeg2decX but there is no sound. I want to rip, edit, and burn without quality loss.
Not that ive done it myself with Final Cut, but i assume all you need to do is get it into a .mov shell....
that would mean
1. demuxing the .vob to .m2v and audio stream (.ac3)
2. opening .m2v with quicktime (assuming you have mpeg2 playack component) and then just save as quicktime self contained.
you could probably mux the .m2v and audio to a .mpeg and then a saving it as a .mov with audio and sound, but doesnt FCP let you mux the audio and video tracks?
Never used FCP so im not sure how it works but you should be able to get the video into a .mov easily and then import it into FCP.
mpg streamclip to convert .vob to .mov
By shard in forum Video ConversionReplies: 2Last Post: 10th Apr 2010, 23:54 -
Want to convert from VOB to .mov without losing quality
By kleiber in forum MacReplies: 5Last Post: 14th Feb 2009, 08:00 -
.Vob to .mov?
By Abiyad in forum MacReplies: 5Last Post: 27th Nov 2008, 19:11 -
VOB to MOV Help
By garboden in forum ffmpegX general discussionReplies: 1Last Post: 4th Feb 2008, 19:34 -
vob to mov
By efb91 in forum Video ConversionReplies: 2Last Post: 27th Dec 2007, 17:07
