I have remuxed my video and my 3 audio tracks I want into 3 VOB files. When I import the VOBs into DVD-lab and then when I'm ready to compile it'll give me an error saying that title 2 and title 3, which are movies 2 and 3 of my 3 movie(VOB) stream, have timestamps of none zero values. Basically DVD-lab is thinking that the 3 seperate VOBs are not part of the same movie, but are simply a string of three unrelated movies and expects each movie to start at 00:00:00.00. I was thinking, should I try and join all the VOBs into one VOB and see if DVD-lab will complain or is this error not even worth worrying about? Will any problems arrise if I joing the 3 VOBs?
Thanks!
Why import VOB files to DVD-Lab? How did you end up with your movie as 3 separate VOBs?
If you are ripping a DVD and re-authoring, I suggest you demux the entire video and audio streams to video and audio files and import these to DVD-Lab.The more I learn, the more I come to realize how little it is I know. -
I tried that, but I can't figure out how to have multiple audio tracks. I've been following a guide called "DVD with multiple Audio Streams - Basic Guide"
https://www.videohelp.com/print.php?page=169251.php
It says in the guide to remux the video file and the three audio tracks into vob files through ifoedit 0.95. Is there another way to have multple audio tracks without having to remux and annd that stuff.
Any help is GREATLY appreciated!
VobEdit - won't join vobs
By bahjan in forum Authoring (DVD)Replies: 4Last Post: 6th Feb 2012, 19:29 -
How to join 2 DVDs which results in more than 9 VOBs ?
By ffooky in forum MacReplies: 3Last Post: 11th Dec 2008, 16:19 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52 -
Are you able to join PAL and NTSC vobs together?
By ramrod1234 in forum Authoring (DVD)Replies: 12Last Post: 26th Apr 2008, 04:27 -
How to join 3 VOBs in VirtualDubMod
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 28th May 2007, 11:09
