I am owner of a Philips DVD player 710 and a Grundig GDV 130.When I play Anime DVD's which I bought per internet from Hong Kong I have problems with the picture when playing on both DVD players.Vertical movements in the picture are ok but horizontal (camera) movements are a little jerky they are not fluid. Second problem When I use Tmpengc to converte a divx file into mpeg1 vcd format I have the same small problems with the picture when playing on both DVD players.Vertical movements in the picture are ok but horizontal (camera) movements are a little jerky they are not fluid.ON PC the divx files are fluid. Does this have to do with TMPENGC encoder, should I use another encoder and which one. As I have an Philips player with FF/RW problems I nead an encoder which adds GOP sequence headers. Can somebody make an suggestion ??? NormaL ORIGIN VCD'S ARE NO PROBLEM. What about my problem whith Anime DVD's does this have to do with mpeg encoding work from the manufacturer (creator) ? On my grundig player I use norm converter to convert signal from NTSC to Pal 50 Hz perhaps the image problems have to do with that ?
Results 1 to 1 of 1
Anime IVTC problem
By AlienWare in forum DVD RippingReplies: 5Last Post: 27th Aug 2011, 13:53 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31 -
short film from Hong Kong Secondary School
By eddielpm in forum Off topicReplies: 1Last Post: 9th Nov 2007, 14:40 -
Prevent automatic scaling/zoom of picture when playing a DVD
By pk20 in forum Authoring (DVD)Replies: 5Last Post: 7th Sep 2007, 04:30 -
DVD media in Hong Kong
By AlanHK in forum MediaReplies: 3Last Post: 19th Aug 2007, 01:04
