I tried making an ISO. The source is an sporting event DVD+RW burnt on a standalone Philips DVDR 75. My intention was to create an ISO and burn to a DVD-R in order to reuse the +RW. The original disc works fine on both my standalone and on the PC. However when i tried to make the image this error occured.
The error occured after about 75% of the ripping process. I tried another disc which seemed to work fine until 98% then the same error occured.
Is there something i can do?
Thanks in advance.
I 13:24:58 DVD Decrypter Version 3.1.6.0 started!
I 13:24:58 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 1)
I 13:24:58 Initialising SPTI...
I 13:24:58 Searching for SCSI / ATAPI devices...
I 13:24:59 Found 1 DVD±RW!
I 13:26:28 Operation Started!
I 13:26:28 Source Device: [1:0:0] _NEC DVD_RW ND-1300A 1.05 (F
I 13:26:28 Destination File: E:\PHILIPS_DVD_VR.ISO
I 13:26:28 File Splitting: Auto
I 13:26:28 Fast Error Skip: No
I 13:26:28 Detect Mastering Errors: No
I 13:26:28 Remove Macrovision Protection: Yes
I 13:26:28 Extracting Sectors... (LBA: 0 - 2295103)
I 13:26:33 Found IFO File: VIDEO_TS.IFO - (LBA: 7168 - 7173)
I 13:26:34 Found VOB File: VIDEO_TS.VOB - (LBA: 8192 - 8351) - KEY: N/A
I 13:26:38 Found BUP File: VIDEO_TS.BUP - (LBA: 14848 - 14853)
I 13:26:39 Found IFO File: VTS_01_0.IFO - (LBA: 15360 - 15399)
I 13:26:39 Found VOB File: VTS_01_1.VOB - (LBA: 16384 - 386623) - KEY: N/A
I 13:30:21 Found VOB File: VTS_01_2.VOB - (LBA: 386624 - 756863) - KEY: N/A
I 13:33:18 Found VOB File: VTS_01_3.VOB - (LBA: 756864 - 1127103) - KEY: N/A
I 13:35:50 Found VOB File: VTS_01_4.VOB - (LBA: 1127104 - 1497343) - KEY: N/A
I 13:38:05 Found VOB File: VTS_01_5.VOB - (LBA: 1497344 - 1867583) - KEY: N/A
I 13:40:08 Found BUP File: VTS_01_0.BUP - (LBA: 1867584 - 1867623)
W 13:42:18 Failed to read Sector 1867664 - Logical Block Address out of Range
W 13:42:19 Failed to read Sector 1867665 - Logical Block Address out of Range
E 13:42:23 Failed to read Sector 1867666 - Logical Block Address out of Range
E 13:42:23 Failed to Extract Sectors!
E 13:42:23 Operation Failed! - Duration: 00:15:55
E 13:42:23 Average Read Rate: 3 911 KB/s (2.9x) - Maximum Read Rate: 6 666 KB/s (4.9x)
I know about this problem "my guess" is that because DVD+RW doesn't require finalization and thats why Decrypter fails when ripping it as ISO.
You can get around with the following settings:
You will get this but this "faulty" image will burn fine:
But if you want it clear rip ALL FILES in file mode then burn with your favourite burning sowftware!You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Thanks, however how do I burn? Do i simply burn the Video_TS directory as i would any normal data DVD?
Also the disc contains an RM directory which hasn't been ripped. Is this created automatically during burning? -
I don't know what that RM directory is but all you need is the VIDEO_TS
You can find some cool Nero guides here
http://dvdshrink.info/nero-video.php
http://dvdshrink.info/nero-udf-iso.php
There are free burning softwares around, do a little search.
PS: That ISO thing works for meYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
ISO the problem?
By Halka in forum Newbie / General discussionsReplies: 23Last Post: 12th Feb 2012, 09:42 -
Problem with .IMG/.ISO file
By macamba in forum Newbie / General discussionsReplies: 6Last Post: 6th Jul 2008, 03:57 -
ISO movie problem
By necrolobes in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2007, 16:52 -
Iso Burning problem.
By whendreamsweep in forum Newbie / General discussionsReplies: 5Last Post: 29th Aug 2007, 10:24 -
DL DVD.iso problem..................
By Waldmas in forum DVD RippingReplies: 5Last Post: 26th May 2007, 15:57
