Hi,
I was wondering if there is a way to capture say from an ADVC-100 using virtualdub, process the capture (noise reduction) and frame serve the output to TMPGenc in one step.
Is this possible, or am I stuck with capturing an AVI and then frameserving the "fixed" file to TMPGenc?
Thanks!
Gary
Results 1 to 9 of 9
Yes you can do it by framserving direct with Virtualdub or avisynth. Tmpgenc has it's own noise reduction filter so you could just use that and not bother framseserving at all.
Just try the options and see what's best for you -
Ahhh, sorry to appear dense but can virtualdub be set to capture, filter and frameserve simultaneously?
If so, how? -
If only!!!
Not a chance.
Virtual dub doesn't give you the option to capture and frameserve at the same time and anyway even if it did Tmpgenc is just too slow to handle it. -
Nope, unless you have a super duper, abacadabra system that NASA is secretly working on..
The closest thing that you could achieve is capturing straight to MPEG2, rather than .AVI... -
And furthermore, the last time I checked, Virtualdub cannot do Firewire captures.
Ian. -
Well, firstly I don't think it would need something super duper system to manage it as long as the transition from capture to processing in virtualdub could be handled by frameserving in the same way as TMPGenc is fed....
I agree about capturing straight to MPEG-2 but... that would leave the problem of cropping the head noise off the bottom of my VHS captures
And regarding DV capture into virtualdub, its possible, because I have done it using the Panasonic DV codec as per a guide I found here or a linked page
As an aside - why are you looking to capture from an ADVC-100 when you already have an ATI Radeon card?
You can capture excellent mpeg2 with this AND use cropping to get rid of your vhs 'noise' from the botom of your captures.
Ah - just had a thought. Are you using the ADVC-100 to bypass macrovision? -
Sure you do..Look at the CPU usage during capture. Look at your CPU usage during encoding. Add the two, together, and you'll need at least two processors, and a motherboard that's resources don't get bogged down.Well, firstly I don't think it would need something super duper system to manage it as long as the transition from capture to processing in virtualdub could be handled by frameserving in the same way as TMPGenc is fed....
Even if that were true, did you ever hear of anybody doing 1:1 encoding in Tmpgenc??
If all you're concerned about is removing the garble from the bottom of your tape, then see if you can capture with the cropping filter included??
Virtualdub kernel32 error, TMPGEnc cutting video
By koberulz in forum Newbie / General discussionsReplies: 5Last Post: 11th Apr 2012, 12:36 -
Realtime Encoding dilema
By OldMedia in forum Capturing and VCRReplies: 0Last Post: 8th Oct 2010, 13:31 -
realtime video on computer
By bakerboy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Jun 2009, 09:18 -
Windows Color Profiles ignored by TMPGenc, VirtualDub, etc. ?
By sanlyn in forum Video ConversionReplies: 13Last Post: 28th Jun 2008, 10:42 -
Changing speed of movieclip to realtime
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 4th Oct 2007, 09:03
