Guess this would be the right place to post it instead...
Hi.
I've bought a standalone dvd-player that supports all sorts of format, but with some of the divX movies I get somewhat blurry image and freezing. The sound carries on as normal thou... Would it be better to try with Xvid instead? Is the quality about the same?
The divX movies are in divX3.11 I belive...
This is the player:
http://www.northq.com/products/dvd.html
Thankful for all help
btw I have done the fimware upgrade...
Most of these new divX platers are having problems with 3.11 divX. In mine Xvid plays great. I have the Lite-On LVD-2001.
I would assume that your player uses the same sigma designs chip as the liteon lvd-2001.
Divx 3.11 codec is a "hack" so there isnt any true support.
Xvid, divx 4, divx 5 are very similar and will give very similar picture quality. All work in a liteon lvd-2001
Divx 5 has the most features, but Xvid is becomming popular. -
Divx 5.x and Xvid seem to be the most appropriate AVI Divx based codecs for the LVD2001. I dont have hard data to support this but this is my suspicion. My bias is the Xvid codec - its free and its quality is good. I would seriously stay away from Divx 3/;/SBC or even 4 if you want to produce playable video for the LVD2001. Watch your datarates too...
What DivX standalone players play "BRRip.XviD" files?
By Stealth3si in forum DVD & Blu-ray PlayersReplies: 8Last Post: 10th May 2009, 22:14 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 09:32 -
Standalone Divx/Xvid player with remote & usb
By bxr510 in forum Media Center PC / MediaCentersReplies: 5Last Post: 19th Aug 2008, 07:19 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25 -
Standalone Divx/Xvid player Q
By g0dm0de in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2007, 00:14
