  1. Group,
    I have a bit of a problem. I just got a the card and I don't get any sound when using the scheduled recording in silent mode. If I don't use the silent mode then it records just fine. I have everything physically setup right with the patch cord running from my sound card to the capture card. The pvr works good as well. Just when I record in silent mode does it not record sound. I use to have this card on another computer and what this use to do was just not turn on the sound to the speakers when recording.
    Any help?
    I have a creative labs Audigy if that makes a difference.
    Thanks.
    --pat
  2. Just my 2 cents.
    If you have not tried downloading new driver from Leadtek website try it now. I have the same card and it works fine.
    Regards
    Dominic
  3. I think I have the latest drivers for the leadtek card. I just installed the latest driver for the sound card (audigy 2). I also downloaded and istalled the lastest version of the pvr software from leadtek.
    I will double check the leadtek card drivers and give it another shot.
    Thanks.
    --pat
  4. What version did you install? Downloading fromthe site it lists this one:
    The latest WHQLed WinFast TV2000 XP Deluxe driver. Update the driver before installing the AP, WinFast PVR.
    ALL_TVDRV_30130.zip
    Is this the right one? The FTP site has many other flavors.....
  5. I am using the one that was released late August.
  6. What is the version of the app that you are using that does work? I don't believe that leadtek has actualy updated the drivers in a long time. They do put out new zip files, but if you look close they actualy contain the same driver files.
    Anyone else have any suggestions? What version of the app has the least bugs?
    --pat
  7. well, I just installed a pretty old version of the app and I still have the sound problem. I get no sound recorded when I choose the silent recording in the record setup dialog box. Maybe I am missunderstanding this option. It is supose to let you record a show with sound, but not output the sound to the speakers while the recording is happening. Is this correct? I leave my speakers on and I don't want a lot of noise from the computer when I am not there.
    Anyway, I went back to install filename ALL_WinFastPVR_30627.exe dated 6/27/03. Winfast version 3.0.9.1. Anyone confirm the exact version they have that will actualy work correctly?
    Thanks.
    --pat
