i have what i think are pal vcd and i think i need to convert them to ntsc so theyll play on my tv (all i get now is a rolling picture in black and white).
my question: is this possibel, if so how do i do it. ive looked over the how to convert section but saw nothing related to this
Try changing the setting on your DVD player. You should be able to choose PAL, NTSC or auto.
yeah, ive tried converting my dvd player, but no luck. when i take it from the default, the picture rolls and is black and white (even with no cd in teh drive) and when the cd is placed in the drive, the same problem --- i think it has something todo with my tv
just an fyi: i had to use an rf converter since my tv only has the "regular" coax connection -- dont know if this is the reason why the tv doesnt seem to support both formats -
I've had to do this, too. I ripped the dvd, per the newbie guide on the left, and just chose the NTSC template in tmp to encode it, and it works fine. You may have to use VCDgear to turn the .dat file back to mpg, then re-encode it with tmp. Possible loss of quality, but it should work.
Liz
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
Converting NTSC-PAL
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 10:06 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
