Results 1 to 10 of 10
    Sydney, Australia
    Excuse me if I am in the wrong forum but I need some urgent help folks. I have a karaoke CD (normal audio CD without lyrics displayed) with three verses but I need to modify it so that the same three are repeated making it six verses (cut & paste somehow?). Any help would be appreciated, included directing me to any other site which may be more appropriate than here.
    Many thanks.
  2. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    If its just an audio CD then you can use something like Cool Edit Pro to copy and paste the section you need.
    you will need to copy it to your harddrive (Cdex will do this) then you can edit it using Cool Edit Pro (or your choice of audio editor)
    Sydney, Australia
    Thanks Sifaga. As it is a one-off excercise for me which I need to do in a bit of a hurry, I'm not too keen to spend big money. Any shareware programs you can think of?
  4. Member Sifaga's Avatar
    Aug 2003
    I hear ya,
    Goto www.download.com and theres heaps there. Audacity is one thats free and popular but ive never used it.
    I would try that one first,
    maybe someone elese can recommend one or confirm that audacity can do this
    Sydney, Australia
    Thanks mate. You're a champion, even if from Melbourne. Just kidding.
  6. Member Sifaga's Avatar
    Aug 2003
    Go Stormers
    Sydney, Australia
    And the Swannies!!
  8. Member Roderz's Avatar
    Jul 2003
    the armpit ofthe Midlands
    Uuuuh heeelloooo - a 'normal audio CD without lyrics displayed' IS a normal audio CD!
    Was that a typo?
    The verses you want to repeat - are we talking just audio or audio+graphics?
    Sydney, Australia
    Yeah, it's a normal audio CD with no vocals, suitable for karaoke singing where I have to know the lyrics as not being a VCD/DVD, there's no lyrics displayed. Just need to replicate certain verses from that to make it a six-verse CD as opposed to the current three verses. Audio only in other words, not with graphics.
  10. Member Roderz's Avatar
    Jul 2003
    Ahh well go with what Sifaga said, my prefrence would be soundforge.
