  1. Virtualdub is OK most of the time for joining AVI files, but a lot of the time I get audio sync problems after the join. Are there any good (free )alternatives, that will join AVI's with AC3 sound?
    Apr 2002
    The State of Frustration
    You may want to look at AviSynth.
    Hello.
  3. Avisyth works OK for joining the video, but I still get sync problems when I join the audio...
  4. Are the FPS and Audio Rates the same? ie both 24fps/30fps and audio is 44.1kHz/48kHz? If they differ, you might want to get them the same before combining them..
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  5. Both FPS and audio are identical...
  6. Try Easy Joiner.. No problem there
