  1. Member dynamix1's Avatar
    Feb 2003
    Atlanta Ga
    I have a mpeg file that is 744mb and I want to put to a vcd to fit a 650mb cd is there a way to compress this file to fit on a 650mb cd. Thanx all.
  2. It will 100% fit onto a 700MB CD-R, you are really close to having it fit on a 650MB CD-R. They hold about 750MB. Oh and is it 744,000KB or is it actually 744MB? If its 744,000KB it should fit on a 650MB CD-R no prob.
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
    Apr 2002
    The State of Frustration
    Hello.
  4. Member dynamix1's Avatar
    Feb 2003
    Atlanta Ga
    after checking the file I have to put on a cd it is a avi/divx I need to convert it to mpeg and then burn to vcd. How to convert divx/avi to mpeg. Thanx
  5. Check the guides section there are many on that subject.
    If it's wet, drink it
    My DVD Collection
