I'm trying to back up my original copy of Mr Show season 3. I had no problem with disc 2, but disc 1 I have. When I burn it , it burns up to 98% and then just stops.....? The program doesn't freeze, it just never moves past 98%. I'm using dvdshrink, a sony dru-500ax with RecordNow DX 4.60. I have tried Imation dvd-r and Philips dvd+r, same result with both. I get no error messege, the program keeps going as though everything is fine, but it stays at 98% and the countdown timer is gone.
Thanks in advance, any input would be helpful
I would make an image using imgtool and burn the image using DVD Decrypter, has always worked for me.
Or try using a different burning program of your choice
use dvd-rw to avoid coasters
does the VIDEO_TS Folder (Output of DVDShrink) play properly
ULead VideoStudio 9 Burning Error
By pcork23 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jan 2011, 09:39 -
Sectors Error While Burning
By rckowal in forum Authoring (DVD)Replies: 4Last Post: 16th Dec 2010, 08:19 -
DVD burning error! =(
By ll ReNeGaDe ll in forum Video ConversionReplies: 44Last Post: 21st Oct 2007, 18:33 -
burning error/disk eject
By djspud in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Jul 2007, 14:15 -
Error at around 20% while burning
By the_rider in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2007, 20:11
