well, just wanted to check some things out:
whenever i play any (s)vcd in my dvd player (pioneer xv-dv303) it is always displayed on the hud : PBC play instead of appearing the movie time...like dvd's...
yet, this will only happen when i insert the cd and push play on the remote....if i push number one, it will then appear the time on the display...
i was wondering if this is normal or if there is anyway to make the movie time appear all the time....
btw, when i put chapters in the movie, i can only go through them like a DVD if i press play at the beggining of the movie...if i press number 1, to see the movie time, then i can't travel through the chapters....
i think this is a normal thing to happen, because its not a dvd, but i just wanted to be sure...
i hope you have understood me...
any help is welcome []
its normal for the pioneer 3x3 , 4x4 , 5xx as far as ive seen
im not sure on all models .. but on several pioneers it did the same thing .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
8) sounds like youa re turning the pbc on or off if its off then you cant use chapters and vice versa.
The electronic components of the power part adopted a lot of Rubycons.
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08 -
how to play mp3's randomly in folder without play lists
By deejay.2001 in forum Software PlayingReplies: 4Last Post: 22nd Apr 2008, 13:27 -
Avid Lquid 7 menus..play chapter and play all
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 01:34
