I'm having a very simple problem with CCE...
I am trying to make a DVD compliant MPEG file. I am pretty sure everything is ok... BUT...
Instead of resizing the avi file, CCE is just basically copying it to a black background. In TMPGEnc I get a nice, perfect sized, full screen MPEG file. But in CCE I get this horrible load of blackness with borders all four sides, and the video, with the same sized resolution as the input just placed in the middle.
This is sort of annoying, because it really defeats the purpose of the encoding to DVD.
ta2
CCE doesnt resize-- you must do that yourself with avsynth or v-dub and frame serve to CCE
Oh, ok... thanks.
Is there a tutorial for that somewhere? And does that make the encoding take longer (by frameserving).
ta2 -
search and you shall find the answer my son. 8)
The electronic components of the power part adopted a lot of Rubycons.
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 12:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 19:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
