I imported a captured MPEG-2 file into Moviemaker and then saved it as DV-AVI, but when I play it back there is a strange little square box which actually consists of a number of smaller boxes that dances around the screen. I have tried rendering the project under different setting as well such as AVI, PAL-DVD etc still the same. However the source file itself does not have this apparition. Furthermore it only seems to affect MPEG-2 files as I have tried editing MPEG-1 and AVI files in Moviemaker and they come out fine
Any ideas ???
hey buddy looks like u're not on ur own there, I am having the same problems as u Im also using Windows Movie Maker. My movies also have squares dancing across the screen. The response is that Tmpgenc and SVCD2DVD should help solve the problems I tried them didnt work for me but it might try to work for u. Others says its completely hopeless to get them back to the way we want it. Im still hoping for the solution for those problems but there seem little point.
Anyway good luck hopes it works out and let me know if u get a result. -
Hey Damsel, found the answer on another forum. Check to see if you have the ELECARD pack installed, if so get rid of it. It seems that when its trial date is exceeded it puts this on any file that it is used to open. Deleted mine and now everything is clear
MediaPlayer 9 not playing MovieMaker wmv
By Punchcard in forum Video ConversionReplies: 3Last Post: 6th Dec 2010, 11:53 -
How do I get my AVCHD into my computer so I can use MovieMaker?
By sisuparker in forum Newbie / General discussionsReplies: 12Last Post: 5th Jun 2009, 08:27 -
Strange box
By BCbear in forum Newbie / General discussionsReplies: 2Last Post: 1st Jul 2008, 22:26 -
Can you convert x.264 to WMV-HD via MovieMaker ?
By Raycaster in forum Video ConversionReplies: 0Last Post: 6th Jan 2008, 17:07 -
Does the Panasonic DMR-ES10S DIGA help jitter/bouncing?
By justinluck in forum RestorationReplies: 6Last Post: 5th Jul 2007, 13:15
