I've got an mpeg1 file that is about an hour long. There are chapter marks (added by vcdeasy) at 20 mins and 40 mins. I now find that I can't edit anything past the first chapter point.
If i try to edit I keep on getting an illegal stream error.
How do I go about fixing it and/or getting rid of the chapter points which are stopping the editing.
Hun?
One uses VCDEasy to create an image file to burn to CD-R. This is the last step in making a VCD/SVCD/CVD. When you create chapter points, they go in a file on the CD, but the MPEG is untouched.
1) Why would you want to edit your MPEG after starting VCDEasy, seeing as how thats the last step?
2) What do you mean by "I now find that I can't edit anything past the first chapter point."
Are you just having trouble adding chapters? Close VCDEasy and start over, make sure you are using VCD2.0 and PBC.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
I didn't realise that. The mpeg was ripped from a vcd.Originally Posted by Ejoc
No,no. Vcdeasy is not running at this step. I am trying to edit the mpeg with just tmpgenc open.1) Why would you want to edit your MPEG after starting VCDEasy, seeing as how thats the last step?
Well, the first chapter point is at 20 mins. I want to cut the mpeg into 3 scenes. If i select the start time anywhere after the first chapter point using tmpgenc's merge and cut then I get the error I mentioned.2) What do you mean by "I now find that I can't edit anything past the first chapter point." -
Whats the end resulting you are going for? You have a Burned VCD that you extracted the MPEG off of. You want to cut it into three seperate mpegs, which you will then...
Does the ripped MPEG play the entire movie start to finish in WMP?
Try womble MPEGVCR to cut MPEGs.Ejoc's CVD Page:
DVD:
Capture:
Unfortunately the demo version of womble doesn't seem to permit any operation to be performed so I can't tell if it would work or not
Do you have any other ideas or program recommendations at all?
Also, i was wondering, would the way I got the mpg from thw vcd make any difference? I extracted it using vcdgear
IFOEDIT edit chapter points?
By wulf109 in forum DVD RippingReplies: 4Last Post: 29th Oct 2011, 20:42 -
have m2v+wav and chapter points, what's next?
By shun in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2008, 09:21 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 13:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 20:33
