Results 1 to 10 of 10
  1. Trying to make a NTSC DVD
    Opend the avi in Gspot and trying to figur out how the script should look like ??
    In Gspot it look like this Video: x:y576x240 (2.40:1) [=12:5]
    23.976fps
    The closest aspect ratio is 1:2.35 ??
    Is it possible to encode this source in 16:9 or should it be 4:3 ??
    I'll try in 16:9 is this right then ??
    BicubicResize ( 720x363 )
    AddBorders ( 0,58,0,58 )
    I calculated like this.... 1:2.35
    480x16:9=853
    853/2.35=363
    480-363/2=58,5 ( 58 )
  2. Sounds like 16:9 to me.
    I use FitCD to calculate my AVISynth resize parameters.
  3. LanczosResize(720,360)
    addborders(0,60,0,60)
    I'd go 352x480, but thats me.
    LanczosResize(352,360)
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  4. Originally Posted by Ejoc
    How is that ??
    Thanks anyway
  5. I've played CVDs (352x480) on my house-mates Sony Trinitron 37" and he was shocked to learn that it was a CD-R and not a DVD. They look good, and are valid DVD video specs, so it can easily be converted to DVD-R.
    Ejoc's CVD Page:
    DVD:
    Capture:
    May 2001
    Or, you could try this:
    bilinearresize(854,356)
    addborders(0,62,0,62)
    bilinearresize(720,480)
    Set your authoring program for 16:9 aspect ratio. This is an anamorphic 16:9 video with the borders. You could also crop off some of the horizontal and eliminate the borders, as in this:
    crop(0,75,427,480) [check the proper syntax - take 75 pixels off both sides].
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  7. Shit ! I can't even add the script in CCE v2.66 ???
    Got error "Frame size 940x56 is not supported,Supported frame size is up to 720x576" ???
    With this script :
    LoadPlugin("C:\Program\Tillbehör\Virtualdub 1.4.9\plugins\textsub.vdf")
    avisource("AManApart.avi")
    TextSub("amanapart21sec.srt")
    ResampleAudio(44100)
    or this :
    BicubicResize(720,360)
    AddBorders(0,60,0,60)
    What the hell is wrong I followed this guide:
    http://www.doom9.org/index.html?/mpg/avi2dvdr.htm
  8. just for giggles try
    #LoadPlugin("C:\Program\Tillbehör\Virtualdub 1.4.9\plugins\textsub.vdf")
    #TextSub("amanapart21sec.srt")
    #ResampleAudio(44100)
    does WMP play it?
    Ejoc's CVD Page:
    DVD:
    Capture:
  9. just to make things eazy on yourself, try to load the AVS file into
    tmpeg first.
    that way you will know if there is a problem in the script,
    avisynth will show you what you did wrong by writing an error message
    in tmpegs preview window.
    cce doesnt preview the clip, so avisynth cant tell you where the
    problem is.
    hope this helps in some way.
    HELL AINT A BAD PLACE TO BE
  10. Christ !!
    It was the avisynth 2.5 !!!
    Uninstalled it and run 2.08 instead
    Ok back to base again...
    Thanks for all the help .
    Happy to be a member here
