HELP!!!!! I am running instantcopy 8 with the latest anydvd.
When I try to make a backup of one of my dvd's, instantcopy 8 tells me that it is copyprotected.
I know that anydvd is running because I can drag and drop the files through windows explorer...and if I use another program such as clonedvd, it works fine.
Any ideas?
Results 1 to 11 of 11
Do you have the latest AnyDVD?
IC8 works fine with my AnyDVD.
- Gurm -
I am using ver 1.6.3.2.....its weird.....it says the files are still css. Every other program works fine accessing them.....just not the instantcopy 8.
And when I uninstalled 8....reinstalled 7.....7 no longer works -
hasn't IC8 has only just been released
and even then I don't think they've started shipping yet
what version of IC8 are you using? -
I had this problem with IC 7. Try the following....
Right click on the AnyDVD Fox Icon in your System Tray. Then uncheck the Safe Mode feature (for some reason this feature defaults to being checked...it should only be checked if you are having a compatibility issue!). IC 8 should be OK to read encrypted DVDs after that.
Mike G.
Thanks...I will try that safe mode trick when I get home....
And to the previous question, I am using a full version of 8....not a beta. I work in techonology at a very large (more than 50,000 people) company and obtained an advance copy. -
I got it working with safe mode turned off.
And spidey, regionfree only makes it region free...it does not get you past the copy protection. ANYDVD does both.....so you don't have to rip the disc to your hard drive -
DVD Region-Free enables DVD copy software such as DVDFab, DVD X Copy XPress, InterVideo DVD Copy, DVD2One, Pinnacle InstantCopy, DVD Shrink and Nero Recode to copy any DVD from DVD drive directly.
A question about the use of anydvd
By wizang in forum Blu-ray RippingReplies: 5Last Post: 1st Sep 2009, 15:14 -
AnyDVD or AnyDVD HD
By Tbag in forum ComputerReplies: 8Last Post: 17th Oct 2008, 22:08 -
anydvd 6.4.69
By shititin in forum DVD RippingReplies: 3Last Post: 16th Oct 2008, 18:12 -
AnyDVD & AnyDVD HD 6.1.8.4 final
By devilcoelhodog in forum Latest Video NewsReplies: 0Last Post: 11th Oct 2007, 21:27 -
AnyDVD & AnyDVD HD 6.1.6.6
By devilcoelhodog in forum Latest Video NewsReplies: 0Last Post: 30th Jul 2007, 16:07
