What's the best software for burning (S)VCD's? I currently use VCDImager Easy 1.01 for just about everything from buring bin/cue images to created VCD's and SVCD's. The only time I resort to using Nero (which hasn't been stable since 5.5.2.4) is if I need to add a simple menu to a VCD.
I use TSCV or just VCDImager to make a bin/cue doesn't really matter what you burn the bin file with (I mostly use Nero).
Actually, it matters greatly if you use Nero to burn a CUE/BIN image. Nero does not do it properly and will seriously stuff up a VCD if it uses menus.
I suggest CDRWin, Fireburner or CDRDAO if you want to burn CUE/BIN images.
Regards.
Michael Tam
w: Morsels of Evidence
burning software
By hardy in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2011, 18:00 -
Best Burning Software
By bmoreravyns in forum Authoring (DVD)Replies: 32Last Post: 14th Oct 2008, 20:46 -
Best burning software???
By Eternal7331 in forum DVD RippingReplies: 8Last Post: 11th Oct 2007, 00:29 -
what burning software?
By dickdb in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Oct 2007, 17:48 -
burning software
By Cmonteith in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 19:07
