Hello all.
I am trying to convert avi to svcd but i get audio sync problem. If i just convert audio with VirtualDub in wav and then run TMPGEnc then audio starts early then it have to be. I tryed full processing mode in VirtDub and save in as avi but i get same thing. What i need to do to make all that good ? Btw this is what i get in VirtDub when i open avi
done that too, btw wav file is shorter than avi file in time, i thought first that was the problem and make it even by add few ms into wav but still same.
are you sure the avi is ntsc and not pal ? if you are encoding in tmpegenc w/ ntsc settings and your source is pal .. your audio is not going to match up ...
in virtualdub , check frame rate of source and if pal , change it to 23.976/24 (if film) ....
then frame serve to tmpgenc ..
personally I load the audio wav file into vegas along with the encoded mpeg file and (preserve pitch / change lenth) stretch the audio till its bang on .. works perfect everytime"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I fixed. It was just avi file with doggy sound in it. I extracted sound and video from avi. Then i loaded both in Vegas (super good program btw) and was playing there for about 20 min before i got video and sound sync. Turn out that sound track was shorter than video but i knew that already, but i did not know that it had to be put in the middle of video. Thanks to all who helped.
MKV to AVI Audio Sync Problem
By adalect in forum Video ConversionReplies: 26Last Post: 18th Dec 2012, 03:09 -
avi audio sync problem.
By Corpsecreate in forum Newbie / General discussionsReplies: 6Last Post: 14th Jun 2011, 12:06 -
AVI audio sync problem
By zakowako in forum Newbie / General discussionsReplies: 0Last Post: 19th Oct 2010, 12:35 -
mkv to avi - audio out of sync problem
By HitcherUK in forum Video ConversionReplies: 4Last Post: 28th Oct 2007, 09:16 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
