Page 2 of 2
FirstFirst 1 2
Results 31 to 36 of 36
  1. Yeah the DVD standard calls for either AC3 or PCM audio for NTSC players (the PAL standard calls for support for AC3, MP2 or PCM). Even thou it's not supported pretty much everyplayer will play it. It's the default audio format for VCD/CVD/SVCD.
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    I'm on an NTSC system, the only difference I notice with mp2 vs ac3 is the mp2 comes through super, super loud on my system - if I do two identical video tracks, but one track has mp2 and the other has ac3 (both from the same wav source) the mp2 track will be twice as loud.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. OK fellas,
    I've got the 3 hour mpeg for the DVD. It has AC3 audio. What authoring program should I use to create a DVD from an mpeg file with AC3 audio?
  4. Member holistic's Avatar
    May 2001
    here & there
    https://www.videohelp.com/forum/viewtopic.php?t=179060
    DVD Maestro : it is free ,widely available and has a friendly 'point and click' interface. :P (now now - don't all pounce at once MOD's that is a joke)
    On a serious note, I recommend DVDLab - Simple but powerful interface.
    Mar 2003
    Uranus
    You can' t do jokes on this forum anymore. There is a self
    appointed policeman lurking about.
  6. I went another route. Capture using Movie Mill 2.0 ( its free ) and allows variable bit rate, constant bit rate captures and selectable resolutions, pcm, or mpeg1, layer2 audio. Then load into MyDvd 5.0 Deluxe which converts the mpeg1, layer2 audio to ac3, add chapter points, and burn. I would not recommend editing with MyDvd 5.0 which it can do but it will then re-encode the whole movie to mpeg2 cbr at 8 Mb/s. It will not re-encode if only chapter points are added and will accept mpeg2 vbr without change.
