HI,
Can anyone help please?
Have just burnt off my 3rd dvd after using SVCS2DVD V1.5 & when I play it on my Sony DVP-NS305 it keeps skipping about 5 mins of the program after a couple on mins normal play!
The 1st disc that I done only had two files on & worked no problem but when I seem to add more than two this seems to happen, also the 1st disc was done from two bin files but the other ones where ripped from vcd's using IsoBuster making them MPG!
Calisto![]()
calistoGuest
If i hear about skipping dvds i think bad media tryanother disc brand.
Greatings,
Yf -
calistoGuest
Hi M8,
Thanks for getting back so quick but have already tried that & still no good, even with Ritek DVD-r! -
Ok second try.
1. did you use chapters?
2. what happens when you put 2 vcd on the disc?
3. what happens when you put more than 2 svcd on the disc?Greatings,
Yf -
calistoGuest
Yes did use chapters
VCD it skips when ripped from cd
SVCD does not skip
Thanks for your help
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
How old is the oldest working burnt disc that you have made?
By yoda313 in forum Newbie / General discussionsReplies: 32Last Post: 14th May 2010, 07:10 -
Audio is skipping when I play videos that are burned on a Data disc DVD!
By Xenogear900 in forum Software PlayingReplies: 8Last Post: 23rd Mar 2009, 14:12 -
captured photo problem when burnt onto disc
By djp in forum Newbie / General discussionsReplies: 0Last Post: 18th Nov 2007, 15:43 -
Removing burnt in subtitles
By Egat in forum SubtitleReplies: 0Last Post: 15th Aug 2007, 03:38
