After compiling no audio on playback, any suggestions?
Maybe an explanation of what kinda files you were working with ? ie... how you created them... and what processes you went through to get to your final product. Also, all programs you used along to way...
This info will help with answering any questions....
Did all the mpeg files check out with out any errors when you imported them into DVD Lab ? -
make sure that all of your audio, for movies and menus, is all exactly the same - don't mix AC3, MP2 or PCM audio in your project.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Another point - no audio at all (play VIDEO_TS folder on PC) or no audio on standalone. If no audio on standalone could be because mp2 audio is NOT supported by the DVD Standard (for NTSC players, even thou most will play it no problem).
Also try manually cycling through you audio streams with your remote (not as much of a problem with authoring yourself thou).
DVD-lab Pro advice for two audio trasks
By blajko in forum Authoring (DVD)Replies: 0Last Post: 20th Jul 2010, 02:33 -
DVD Lab Pro Audio Problems
By Outcast212 in forum Newbie / General discussionsReplies: 6Last Post: 21st Feb 2009, 03:11 -
No audio and subtitles in DVD-lab PRO2
By 6ZIX in forum Authoring (DVD)Replies: 13Last Post: 11th Feb 2009, 09:14 -
dvd-lab...no audio
By sylvester243 in forum Authoring (DVD)Replies: 2Last Post: 11th Jan 2008, 03:00 -
dvd lab pro audio error
By tomoftenville in forum Authoring (DVD)Replies: 7Last Post: 6th Dec 2007, 17:05
