I recently brought a Pioneer dvr-a06. I have backed up several movies so far with out a problem. My question to you guys is do you think using my dvd +-rw drive to rip the movie will do any damage to the drive. I have a dvd-rom that i currently use. Just wondering if anybody had any guidance on this. Thanks in advance for the help!
Results 1 to 9 of 9
I would not say that it would damage it but obviously you are going to making the laser read more which will add more wear and tear to the drive.
Personally I would continue with your current method. -
If you have both drives a reader only and a burner, I would use the reader. May depend on drive types But I think you might actually get faster ripps. For sure using a $30 drive will save wear and tear on the burner
IF you need to pull the reader for some reason like to install something else on that connecter, it shouldn't hurt to ripp with the burner, it just gets more use and may wear out faster is all. But then agian, by the time it wears out you can proably replace it for $60, it won't happen over night
pray tell what does it burn to then? thin air?that will let you rip and burn without physically removing the original disc and putting a blank disc in..Corned beef is now made to a higher standard than at any time in history.
I guess Shaw was right when he said we were two peoples separated by a common language.
Anyway, RabidDog, what I think Gil T Pleasure is saying is you put the original disk in the DVD-ROM and the blank disk in your burner, select your options and start the procedure. Then do something else productive. Later, when you realize what you had been doing in the first place, you open your burner and remove a brand new copy of the original. No disk swaps, no waiting on the rip to complete before burning, etc. I hope I was more clear.Hello. -
ive ripped and burnt over 400 dvds on my pioneerA05,and its still working fine.-and its only 4 months old.
youll have a years guarantee,so i wouldnt worry about anything in the first year..hehe. -
Lets see! I can replace my DVD reader for about US$45.00 but to replace my DVD writer I would have to fork out around US$162.00.
This is starting to look like a no brainer to me!!
Thanks for the clarification, Tommyknocker. I couldn't have said it better myself.Originally Posted by Tommyknocker
:P
Can I use my DVD Drive to Rip Blu-Ray Movies ?
By augustya in forum Blu-ray RippingReplies: 25Last Post: 2nd Mar 2012, 14:07 -
Best way to rip blocky or Compressed Dvd movies?
By Bharathnat in forum DVD RippingReplies: 7Last Post: 4th Nov 2011, 11:55 -
DVD player's copy protection won't even let me rip home movies.
By Brian. in forum DVD & Blu-ray RecordersReplies: 12Last Post: 27th Mar 2011, 16:12 -
Want to Rip DVD movies !
By augustya in forum DVD RippingReplies: 23Last Post: 24th Sep 2010, 21:57 -
how to rip movies into a CD which is playable in home DVD players?
By vain in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2009, 10:25
