I would like to try tweak drivers for capturing, the problem is that when I install it, if I try to run MoreTV the system hangs, and obviously I don't want to miss that application.
Is it possible to have standard and tweak drivers both installed so that I only have to choose one configuration or the other depending on the application I want to run. If so, how can I do it?
Thanks in advance
Results 1 to 1 of 1
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 10:44 -
Help with re-installed XP operating system - Drivers Needed
By jeanpave in forum ComputerReplies: 11Last Post: 26th Jul 2011, 21:51 -
Adobe Premiere Elements 2.0 and 4.0 installed at the same time
By Mållgan in forum Capturing and VCRReplies: 0Last Post: 26th Aug 2009, 02:21 -
No stereomix after installed Realtek drivers!
By LoveMyslf in forum ComputerReplies: 6Last Post: 6th May 2009, 16:18 -
To Capture or... To wait for drivers?
By Yeah in forum Capturing and VCRReplies: 3Last Post: 12th May 2007, 18:31
