  1. porksausage
    Guest
    Hi,
    Does anyone know o has anyone tried to run both V1.1 and V1.5 of SVCD2DVD[MPG] on the same system and can they co-exist?
    I just want to check before I try V1.1 again?
    Thanks.
    Ray
  2. The better option is to uninstall the v1.5 version and reinstall v.1.1
    Greatings,
    Yf
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    v1.1 - the freeware version cannot coexist with v1.5
  4. porksausage
    Guest
    Hi ChrissyBoy,
    I am a registered user of the SVCD2DVDMPEG+ - Would this co-exist with SVCD2DCD V1.5 then?
    Ray
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    No - afraid not. The idea behind it is that i only want to focus on supporting one version - the latest.
