I though KDVD would be the answer i was looking for regarding getting more movies on one disc.
I converted 3 divx movies with the KDVD preset, i had to change the ratio for a couple as they were all different.
The results viewed with VLC were great, and the file sizes were very good.
I used Sizzle to create the menu and to link up the tracks with thier audio files. I couldnt use DVD Studio Pro as it didnt like the m2v files.
Anyway, i burned the disc image produced by Sizzle.
In the apple dvd player the menu worked fine and the movies did play but the top half of the screen was bright green. I thought this was just the player. I dragged the vob files onto vlc and they worked great.
I tried the DVD in my PS2 (as my normal dvd plaver doesnt like any burnt media)
Again, the menu worked fine. But each movie gave different results.
One would have the right half on the screen suttering with the previous menu graphic and the movie would start to play but only the right hand side of the 16x9 in the left side of the screen (if that makes sense)
One movie would play but stutter heavily, only about 1 or 2 frames a second.
The third film, played ok, though outlines on shapes and edges appeared to be very jagged. Im guessing this may just be do to the low quality but it is watchable, though not as good as when viewed on my mac.
Anyone else use KDVD?
I really want to get more than one film on a dvdr, can i do it the normal way but with a very low bitrate so that the target size for both sound and video is under 2g?
Or is it just my PS2? It plays normal dvdr created with studio pro and idvd.
sam
thanks that worked great
not as small sizes as the original preset but enough to get two on one dvd
interestingly we got a new dvd player this week and tried the disc i burned in my first post that didnt work on the PS2
and this time i got different errors, still didnt play properly though
but thanks for the advice
i just wanted to say it worked in case others have similar problems
KDVD and nero
By silkk504 in forum Authoring (DVD)Replies: 6Last Post: 7th Sep 2008, 15:49 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
KDVD Help
By dbanga in forum Authoring (DVD)Replies: 6Last Post: 25th Jun 2007, 19:39 -
Help Xvid to KDVD
By dbanga in forum Video ConversionReplies: 4Last Post: 21st Jun 2007, 15:27 -
burning kdvd?
By syun_ukiya in forum Newbie / General discussionsReplies: 3Last Post: 7th May 2007, 04:14
