I want to create a backup for a data dvd that i have. The problem is that it is over 4.7 gigs (similar to the dvd-9's seen in dvd videos). Is there any way that i can copy this type of data dvd onto a standard dvd-r 4.7gig disc. Thanks
I think 4.38 is the max size of a DVD blank
I think you can over burn a little bit but then you may not be able to retrieve your data, is it wirth it?
how much more over is the data
is it already compressed can you compress it -
The best way is just to compress it if you can. Zip files whatever.
A DVD-RAM would fit it, but those are not very common.
Or split it into two disks. If you want a single disk, I heard that there are some very expensive dual sided DVD-R's for sale. Never saw those myself, but you would still have to flip the disk over."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
8) if you can write dvd-ram these are vaailable in 9.8gb size (biggish bucks) or try to compress the file? or use some sort of compressor/file splitter to make a backup in 4.7gb chunks (probably just two)
The electronic components of the power part adopted a lot of Rubycons.
How do I backup data to CD or DVD and have the data encrypted?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2011, 18:53 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 09:00 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
Copy data from DVD to external hdd= a pain
By themaster1 in forum ComputerReplies: 2Last Post: 11th Jun 2008, 14:04 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 12:23
