Hi,
Has anyone been using Dr Divx and getting a slew of bad frames. The video runs fine in Windows Media Player and also WinDVD but when you load it into VirtualDub, it says that there are like over (at least) 1300+ bad frames. Fact was, I didn't realised that this was the case and did about 10 odd movies already through Dr Divx (they all played fine in WMP and WinDVD and I thought nothing of it - thinking it was a good encode because they were all watchable). The only thing that I changed in the Dr Divx settings was to a Bicubic Neutral (i think it defaults to Sharp) but all the other settings (besides the bitrate) was left alone.
Would fixing them (deleting the bad frames) cause any problems here? It's just that it took a long time to do 10+ movies
Cheers,
feeras
o wouldnt rely too much on those being real bad frames if those movies play fine and you are using the defualt settings you cant have done too much wrong. Be strong, self-doubt leads to indecisiveness and lack of moral fibre.
I get the same thing and it didn't affect the bottom line one bit. I encoded 4 30 minute episodes that were in some unknown codec w/Dr. Divx, then used virtualdub, then TMPG and popped out a very high quality svcd and only took a few hrs.
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
Defragmentation leave lots of bad sectors on a new disk
By dmedina in forum ComputerReplies: 5Last Post: 25th Feb 2008, 13:25 -
Does current ADStech Pyro (firewire) w/Premiere still drop lots of frames?
By miamicanes in forum Capturing and VCRReplies: 9Last Post: 19th Sep 2007, 23:41 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 03:39 -
Daytek DVR-P30: lots of 'fails' when erasing, lots of nothing when recordin
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Jul 2007, 15:43
