so can someone point me to a pal to ntsc conversion guide
Originally Posted by billyt
The best thing to do here to to RIP the DVD in FILE MODE and select just the main MOVIE and run the VOB files through DVD2AVI so it spits out your audio (most likely AC-3) and a D2V project file.
Here is all the info you will need:
http://www.geocities.com/xesdeeni2001/StandardsConversion/
https://www.videohelp.com/forum/viewtopic.php?t=160433&highlight=
The first LINK above will take you to Xesdeeni's website where most of the INFO you need to know is located.
The second LINK is a previous THREAD from this very website where a few people (including Xesdeeni as well as yours truely) hash out the gritty details ... more or less
or just drop the mpeg and converted wave into vegas and select ntsc output (or 23.97 film), keep aspect ratio , flicker remove (optional) , select 2 time over sample and "good" or best quality and render to a mpeg and new ac3 file ...
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
Simple click and go method to convert PAL to NTSC
By THRobinson in forum Video ConversionReplies: 15Last Post: 26th Feb 2011, 00:16 -
.iso NTSC to PAL with subs
By LoveMyslf in forum Video ConversionReplies: 17Last Post: 12th Jun 2008, 11:01 -
Converting PAL ISO to NTSC for DVD-Video
By Nate7410 in forum Authoring (DVD)Replies: 1Last Post: 18th Sep 2007, 14:27 -
DVD ISO, PAL to NTSC help
By hiro24 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 01:17
