I'm doing a media project for school which basically involves matrix style fighting, some cool matrix effects, yadda yadda. I'm in great need of sound effects that are used during the slow motion "bullet time." Also, some sound effects when the agents dodge the bullets. Also, I need sound effects for the falling matrix code, used in the beginning title sequence, kind of a twinkling noise (this may only be in Matrix Reloaded, I haven't seen the first one in a while). If you have questions on what I need, I'll be more than happy to reexplain. If anyone has links of where I can find some of these sound effects, or has them laying around, I would really appreciate it if you could hook me up. I've searched the net, but all I've found were sound clips of movie quotes.
Thanks a lot,
Mojo
I'd do a google search for Matrix sound effects, or if you have the DVD on the movie, insert in computer DVD and set audio mixer settings for wave or what U hear and record using audio software (make your own).
Perhaps rip the DVD of the first movie and then separate the video and audio into two separate files.
Then just load the program into a sound editor and crop the bits out that you want. -
Unfortunately, I don't have a copy of the movie, but I do understand what you're telling me to do. Google didn't help much, the only sound files I found for the matrix were quotes (mentioned in my first post).
Thanks for the suggestions so far!
Help! When I render a video in Adobe After effects, theres no sound!??!?!
By Devilsadvocate in forum EditingReplies: 4Last Post: 21st Mar 2012, 09:02 -
How do I Rip sound effects and music separately?
By tapir in forum DVD RippingReplies: 9Last Post: 19th May 2010, 01:04 -
After Effects error: opening sound component (-2166)
By santolina in forum EditingReplies: 0Last Post: 24th Apr 2010, 08:36 -
How to find moive sound effects?
By squeejiboo in forum Off topicReplies: 2Last Post: 29th Aug 2008, 07:04 -
Sound Card Compatibility with After Effects CS3 Issue...
By Angelus22 in forum EditingReplies: 1Last Post: 28th Oct 2007, 07:20
